To-20 hydraulic pump question
andy (ky)
07-21-2001 09:22:02
my lift shakes as it raises.pulled side cover off ,and put pump in gear,fluid was shooting out the side of pump.the square gasket is blowed on side of pump.my question is should i buy a hole rebuild kit (233.00)or 2-square gaskets (2.00)each.should i rebuild the hole pump or just replace the leaking gasket? thanks in advance,andy
marlowe
07-21-2001 10:52:25
 Re: to-20 hydraulic pump question in reply to andy (ky), 07-21-2001 09:22:02
i would sure try the 2.00 gaskets first because it is not hard to drope the pump agian if the gaskets don't fix it 2hr. max and you sure can save the oil if clean but it's your choice a little time or 233.00 good luck
