Back blade
Gunnar
07-25-2001 04:31:07
Just want your experience guys. How wide (and heavy) backblade is possible to use behind a TEF20 for removal of snow?
Gunnar.
Barry Reid
07-25-2001 05:49:26
 Re: Back blade in reply to Gunnar, 07-25-2001 04:31:07
I currently run a 5ft wide blade, But it still makes tuff work, looking back all the time is hard on the neck, good luck
drizler
07-27-2001 23:17:31
 Re: Re: Back blade in reply to Barry Reid , 07-25-2001 05:49:26
I have used a 7' blade in Northern NY for the last 5 years. The machine will drag snow up to 8" or so and it allows me to angle the blade to the side and it is still wide enough to be wider than the 5' tractor. I clear a 900' driveway and the angle comes in handy. You can always cut it shorter if needed. I do most clearing going forward as these things aren't grand in reverse when the snow gets deep or heavy and you GOTTA HAVE CHAINS. Plowing without them will cut your ability by 1/3 or more, I know I have misplaced mine a few times. A Zane Thang is also quite helpful for $80.
