Bucketloader/hyd filter
art
07-25-2001 19:05:37
i am working on a to35 with z134 engine for a friend and upon getting to the hyd pump for loader(made by midwestern industries in wichita ka. model 101)the filter thats located on end of pump has a filyer with a outer screen and a inner cannister which looks close to the filter on the engine.
my problem is they are so plugged they collapsed!!
the screen i may be able to salvage but none of my filter books give an application.
the closest i can get is hastings lf 130 or lf 202 but there actually oil filters so i'm not sure if i should use them.
anyone with # or places i can locate inner and outer filters would be grestly appreciated
also am making it changing bat. from pos ground to neg. wiring is all screwed up and looks like it was originally neg. ground thanks art thanks art
Phil (VA)
07-26-2001 07:00:35
 Re: bucketloader/hyd filter in reply to art, 07-25-2001 19:05:37
Don't know about pump filters. Is tractor 6 volt? If so, probably should be positive ground. Lots of posts and archives on that subject. If you have questions about that, I'm sure lots of people can help.
art
07-26-2001 11:14:29
 Re: Re: bucketloader/hyd filter in reply to Phil (VA), 07-26-2001 07:00:35
it's 12 volt.
thanks for the reply, i'll keep searching. art
