3pt. hitch lower arms
Boogity in S.W.
07-31-2001 15:37:08
During my clean-up and engine overhaul (I do not want to call it a restoration) I discovered that both of my lower 3pt. hitch arms are badly worn at the tractor end. I can also see that one has been poorly repaired and ready to fall apart. Does any of you have two arms to sell or where can I find them? I have sent several tractor parts inquiry forms from their web sites. No answeres.
Joe in NY
07-31-2001 18:01:58
 Re: 3pt. hitch lower arms in reply to Boogity in S.W. Ohio, 07-31-2001 15:37:08
Lower links can be had at Central tractor or whatever its called now. Ford links fit these machines. TO series. I think the heat treated ones go for about $50 bucks per. New balls can be welded on your arms also. That is cheaper. Just cut the old ones off and weld the replacements.
Good luck,
Joe
