Fergy clutch
NORRIE CHRISTIE
08-06-2001 07:20:40
I have inherited a Ferguson TE with P3 fitted.
The clutch engagement is savage to say the least.
Anyone any thoughts before I split to investigate.
Jim In Scotland
08-11-2001 11:11:06
 Re: Fergy clutch in reply to NORRIE CHRISTIE, 08-06-2001 07:20:40
Most probabally oil contamination of the cluch plate .Does she drip oil from the drain hole just nder the cluch assembly ??. Mine has a small leak which is ok if not used to much the oil ket a chanch to drip from the shaft she also leaks bad from the input shaft when loading up ramps etc I try to avoid going up steep inclines to keep the oil from racing forward and into the cluch ..
