30 engine locked-up
Otis
08-12-2001 06:28:27
The other day I was mowing and I noticed a significant loss of power. I disengaged the pto and heard alot of rattling and knocking. I shut it off and pulled it back to the garage. The oil level was good and so was the water level. It would crank but wouldn't start. The next day I used jumper cables to start it and it knocked pretty loud. I immediately turned it off. Since then the engine won't crank and I can't even turn it over by hand. Any suggestions? Thanks for your input.
Otis in Oklahoma
08-14-2001 08:14:49
 Re: 30 engine locked-up in reply to Otis, 08-12-2001 06:28:27
I removed the cylinder head and the oil pan and found what appears to be the retainer for the ball bearings from the governer in the oil pan. The rods, piston, & cylinders all appear to be in good shape. Haven't gained access to the governer yet to see what it looks like. Any ideas on what caused this or what to look for?
Otis
08-12-2001 09:59:53
I haven't gotten an overhaul manual yet, do you know if you have to split the tractor to drop the pan? Oh by the way I entered 30 erroneously, it's actually a TO-35. Thanks for your input.
Otis in Oklahoma
08-14-2001 08:22:09
 Re: Re: 30 engine locked-up in reply to Otis, 08-12-2001 09:59:53
I removed the cylinder head and oil pan. In the pan I found what appears to be the remains of the governer bearing retainer. I haven't gained access to the governer yet. The pistons, connecting rods, and cylinder walls appear to be good shape. Any idea what caused this or what to look for?
dennis
08-12-2001 11:31:31
nope, just take out the bolts and it'll come down, but it's kinda heavy so be careful when the gasket breaks loose.
John, IN
08-12-2001 07:43:34
I would drop the oil pan and have a look see. Sounds to me like you may have lost a rod.
