F-40 Stuck in Reverse Gear
Ted Nixon
08-14-2001 16:24:03
Engine Runs Great ,PTO Engages Great,Clutch Works
Tractor Runs Great except only in Reverse
I put the tractor in reverse to move and it will not come out of gear. Runs fine but only in reverse. Tried to bump the gear shift will not come out of reverse. Please help with suggestion
thanks
S.Neill
12-08-2001 15:22:57
 Re: F-40 Stuck in Reverse Gear in reply to Ted Nixon, 08-14-2001 16:24:03
stick a level into oil filler hole and put the furtherest away selector in line with the 3 & 4th selector (nearest to you)may have to start the tractor and put range select lever in neutral to do so. email me if you are stuck with your phone number and I can talk you through it
08-16-2001 16:16:09
Did you remember to Double Clutch it?????
