Ferg.lights/tool box
Skip
08-21-2001 07:20:27
I was looking at 2n ford/ferg,it had lights/wings,the bezel had two screws holding lens in. Are these ferg.? They were large about 6"around.There was also a work light with a switch that matched the head lights not on tractor.Tool box was approx. 7" wide 6" deep 22" long on left rear fender ,that mounted on 2 rear light brackets.It did not looked cobbed up,I have never seen these on fords are fergie?.Any help on this would help me determine value of tractor .Thanks skip
David, MI
08-22-2001 07:33:31
 Re: ferg.lights/tool box in reply to Skip, 08-21-2001 07:20:27
Phil: From my research/understanding, what you describe could indeed be Ferguson. The front lights have wings and two screws that held the lens/sealed beam in. There was a red tail light (left side) and a removable work light (right side) that had a switch. What is really difficult is that many times lights were not standard and may have been added later. None of this stuff is available today, except used. I am not knowledgeable enough to comment on the N Series Fords, except that what I have seen is similar (in appearance) to what the parts catalogue shows for the Ferguson TO-XX & TE-XX tractors. The catalogue shows a tool box like the one you describe, but I cannot remember which model (TE-20/TEA, I think, maybe a TO-30).
A few months ago, I tried to find original/close to original rear lights for my TO-20 and I could have purchased a used rear work light for about $90.00--seemed steep to me, given my plan is not to show the tractor but to keep it as original as possible, but mostly functional for use. During my search, I looked at a lot of Fords that for the most part did not have wings on the front lights, they were marked with "Tracto Lite" (was marketed/packaged by Ferderal Mogul until Ford got out of the tractor business) and the lens was held in with a ring that had one (possibly two?) screws that clamped it tight around the headlight body.
If you want parts numbers for early Fergusons, let me know, and which parts.
David, MI
Phil Fenner
08-22-2001 17:58:36
 Re: Re: ferg.lights/tool box in reply to David, MI, 08-22-2001 07:33:31
I have been diligently looking for original lights for my TO-30 and have only found the rear work light which I got for around $20(brackets were included) but was restorable condition. So, $90 seems very high , but I might pay close to that for the red tailight with good glass and restorable, but don't tell the wife. As far as tool boxes go, the TO-30 had an integral box built under the hood. The external bolt on was used on the 20 series. This is what my parts book shows from Ferguson anyway.One more thing on the rear work light is that it is to be mounted with a wing and in a horizontal position, not upright like Ford.
Phil (VA)
08-21-2001 11:22:17
I have a TO30 Fergie with a toolbox like the one you mention. It is mounted on left fender and the mounting is part of the light bracket. I am not near my tractor, but the size sounds right. I have not seen one like that on a Ford. I think it is a Fergie item.
