Need info on a compensator spring
Boogity TO-30
08-21-2001 20:12:29
I'm in the final stages of my engine overhaul and paint-job on my TO-30. I was making my final adjustments on the governor linkage and discovered that my compensator spring is broken. It's the coil spring that attaches to the water pipe goosneck under the gas tank mounting flange. It attaches with a cotter pin. The other end attaches to the swing arm on the governor U-bolt piece. Since it's broke I can't measure it's length nor can I measure it's weight or strength. Can any of you folks tell me the total length and the spring tension in pounds? Anybody know where I can get an original? Thanks, Boogity
Neal(IN)
08-24-2001 04:32:41
 Re: Need info on a compensator spring in reply to Boogity TO-30, 08-21-2001 20:12:29
If you want I will check with the salvage yard near me and if they have one I can send it to you.
Or if you want you can look them up at www.junktractors.com and give them a call.
Neal
Paul in NM
08-22-2001 15:18:28
Call Mac Tractor Parts at 1-800-882-4742 and they will fix you up with a good used, original one in short order.
Paul
