FE35 Diesel Smokes
Harry
08-31-2001 15:06:29
I have got a FE 35 with 4 Cyl Standard engine. The engine has been fully rebuilt, new rings, pistons, liners and valves, injectors tested and serviced and runs well, but difficult to start.
The trouble is that it produces a lot of white smoke when running. could anyone help because i have spent a lot of money on this machine. Thanks
Malcolm
08-31-2001 18:06:59
 Re: FE35 Diesel Smokes in reply to Harry, 08-31-2001 15:06:29
White smoke when first started usualy means low compression. If the white smoke stops when ths engine warms up an the rings have expanded then this is probably the problem.
Regards Mal
