Ferguson T0-20 ampmeter and hour meter
Sandra
09-02-2001 16:48:20
I am the proud owner of a TO-20 with some basic questions. I'm not sure if the ammeter is working. Should it register while the tractor is running; should it move while the starter is cranking? Also can I just hook up an hour meter to keep track of the usage. I have an electrical wiring diagram for a 6-volt gasoline TO-20 which shows an hour meter hooked up between the ignition switch and the coil. Any help would be apprecaited. Thanks
