Carb. adjustment on a 1953 To-30
Mike Taulbee
09-08-2001 13:10:41
I put a new carb. on my To-30 and it runs alot better but I still think it needs some adjustment can some one out there help me out? I am not sure which screw does what. Thanks Mike
Boogity TO-30
09-08-2001 18:31:01
 Re: carb. adjustment on a 1953 To-30 in reply to Mike Taulbee, 09-08-2001 13:10:41
I recently rebuilt my Marvel-Schrader (sp??) carb. and the settings that were provided in my shop manual seemed to be great for the initial start-up.
The small knob is for low speed and the intial setting is supposed to be 7/8 of a turn open. After many small adjustments I have ended up with about 7/8 of a turn open at around 450 rpm.
The large knob located toward the front of the carburator top, slightly angled, is the high speed jet adjustment. This initial setting should be 1 1/4 turn open. Again after many small adjustments at about 2200 rpm under a load I ended up with 1 1/2 open for best performance. We are cautioned to never operate the engine with this setting at less than 1 1/4 open because the engine needs the cooling effect of the gas/air mixture and anything less than 1 1/4 turns open may allow some over-heating in the intake valves.
I hope this helps. Please let all of us know what your final settings become.
Boogity
Mike Taulbee
09-09-2001 09:01:05
 Re: Re: carb. adjustment on a 1953 To-30 in reply to Boogity TO-30, 09-08-2001 18:31:01
Boogity I tried your settings this morning the ferg. seems to run alot better I will use it tomorrow under load to make sure but I think its fine Thanks for all your help Mike
