Hydraulic lift problem TO35
Boo R- Alex,La.
09-08-2001 17:25:13
I had just finished disking and was traveling with the disk up when the hydraulics gave way. Now the three point lift does not lift. Any suggestions? Also, the serial # is TO35 143268. Can anyone tell me what year this tractor is?
Bob in CA
09-08-2001 21:56:47
 Re: Hydraulic lift problem TO35 in reply to Boo R- Alex,La., 09-08-2001 17:25:13
According to your Serial No. it should be a 1955. You can check this out on this site under the serial number section. I have heard of the hydraulic piston breaking under heavy loads. You can check the pressure output of the pump with a 3000 PSI gauge at the block under the seat. The IT manual descibes checking the pressure. There should be a way to hold all fluid to check output without regard to the piston condition.
