Ignition switch on Fergie
Ark Pisarevsky
09-25-2001 05:02:42
Has anybody installed a car style ignition switch on the fergie to replace the shifter start ?
I seem to have a lot of trouble getting the contact to engage after it sits for a week or so.
Ark
Jon
09-30-2001 15:43:58
 Re: Ignition switch on Fergie in reply to Ark Pisarevsky, 09-25-2001 05:02:42
Also try cleaning the contacts in the shifter switch, they often oxidise
Phil (VA)
09-25-2001 06:58:47
The original equipment switch slides slightly to adjust. If you are not making good contact, loosen the bolts and slide it -- I forget which way, but you can experiment -- to make the contact between the rod and the switch button closer. The switch itself, hidden under the four bolt cover, is same basic button as the push button on a Ford Jubilee, etc. In other words, the Fergy switch button is probably as good as any other, just hidden. My suggestion is to try the adjustment first. Besides, adding a switch might mean cutting up your dash, lessening the value of your tractor, and it would eliminate the safety feature (can't start in gear) of the OEM switch. Just my thoughts. Hope it helps.
