Oil change
Bill
05-25-1999 06:50:59
Have a tea fergie and would like to know how the heck you change the oil. Everything is welded shut. also I need information on the Zenith cabuerator. I tried to interchange with a marvel shrebler there is a slight difference in the mounting holes is ther a kit available. also it is very hard to get info on parts for these tractoes can any one help. Thanks
kevin
05-26-1999 05:43:48
 Re: Oil change in reply to Bill, 05-25-1999 06:50:59
Bill:
There should be a plate on the bottom of the oil pan with two bolts in it. The bolt in the center of the plate is to remove the plate which is what one does to replace the oil filter. The other bolt is the oil drain plug. The removable plate has a gasket that seals against the oil pan. From your description, I would say someone has welded the plate to the oil pan. If this is the case there may still be a drain plug present, but you would have to take the oil pan off to change the filter. If there is no drain plug then you may need to buy a new or used oil pan.
