Blue smoke
gerry
10-23-2001 18:43:32
my motor runs good but it smokes at wide open throttle now the motor is suppose to be brand new but it still smokes. it has a new head so im thinking it could be the rings but not sure. i took the plugs out and theres oil on them and when i take the oil filler cap you can see oil blowing out a little bit. what would be the problem here? plus the crank slides back and forth a little to how much end play should there be?
DunerWi
10-25-2001 06:39:03
 Re: blue smoke in reply to gerry, 10-23-2001 18:43:32
Crankshaft end play should be .003 to.007 for the Continental engine.
tim shumbera
10-24-2001 19:16:12
Well, Gerry, it doesn't sound as if you're sure if this engine is brand new. If your engine is brand new and the rings have seated properly then you shouldn't experience this problem. The engine needs to run through a break-in. An hour of various throttle openings and loads would seat the new rings. No heavy loads or high throttle settings until the engine has had at least two runs up to operating temperature and cooled down. Could be that the cylinder hone job wasn't done correctly if you're still getting "blow-by."
If the engine just has a new head then various problems could exist:
A bad mate between the new head and the old block.
Head bolts aren't torqued correctly.
New head is warped.
Valve seals were damaged when installed.
Check for oil in the coolant. Check for coolant in the oil.
It could be that one or more of the oil control rings was damaged when the engine was rebuilt.
Also consider that 50 years ago tolerances and mating surface weren't measured in the ten-thousandth inch as they are today. Even brand new engines in the 50's smoked a little under load.
Hope some of this helps. Tim
Pete Tatham
10-24-2001 00:40:05
Gerry, What you discribe are the classic signs of a worn engine and I'd bet money that you have worn liners or rings or both. Only way to find out for certain is to do a compression test on all cylinders. A search of the archives on this site will give you all the info you need
Regards,
Pete.
gerry
10-24-2001 09:24:25
 Re: Re: blue smoke in reply to Pete Tatham, 10-24-2001 00:40:05
i did a compression test an have 140 psi in all cyls i did find out that the plugs where gapped at .020 instaead of .035 so i changed it and it run alot better and no smoke or the little pop i had.
willis
10-25-2001 18:29:03
 Re: Re: Re: blue smoke in reply to gerry, 10-24-2001 09:24:25
This sounds just like my TO-20 I got it about a year ago. The crank end play was about .030 so i used it for one summer. Bad mistake. The preivous rebuilder put the front thrust washer on the crank backward. When I took it apart, the front of the liners were groved. The crank and block were also groved. After $1000.00 worth of parts and machine shop work it is good as new. Don't be like me. Fix the end play now.
