Stuck leveling bar
Andrew
11-03-2001 23:45:51
I have a Fergy 20. The leveling bar, that adjusts the height of the right lift arm, is stuck. I don't think its' rusted solid, but copious amounts of CRC haven't budged it. I don't want to lean too hard on the pipe wrench unless the bar breaks. Any suggestions would be appreciated. Thanks
Phil (VA)
11-05-2001 08:42:50
 Re: stuck leveling bar in reply to Andrew, 11-03-2001 23:45:51
If you didn't already, remove it from the tractor first and put it in a vise to work on it. That way worst that can happen is you mess up one thing, and it is replaceable.
Andrew
11-06-2001 00:19:54
 Re: Re: stuck leveling bar in reply to Phil (VA), 11-05-2001 08:42:50
Thanks, I've tried to get it off. I got both the pegs off the top part, but the bottom bolt has proved difficult. All I know is that the nut comes off, but with the nut just on, several blows with a small sledge hasn't budged it. Is it threaded on the left side aswell? Also, how much would a replacement cost, roughly? Thanks.
Phil (VA)
11-06-2001 08:47:45
 Re: Re: Re: stuck leveling bar in reply to Andrew, 11-06-2001 00:19:54
Not near my tractor now, but it should come off. As to cost, try the salvage yards first, maybe $50 for unit? I bought fancy aftermarket version recently (top and bottom are two items sold separately) and the total for both pieces was around $90. The catalogs have them. You can get poor mans version with rod like top link turning rod instead of screw handle and those are cheaper; and if you don't do a lot of work with a back blade, etc., that might be good choice, but would be difficult from tractor seat.
ATS
11-11-2001 17:00:37
 Re: Re: Re: Re: stuck leveling bar in reply to Phil (VA), 11-06-2001 08:47:45
Contact "EO & G's farm center at (334) 745-0044.
i am looking at their catalog and new unit for your tractor is $14.19. This is for the top half.
You should be able to seperate them once you get them off.
Bowser
11-04-2001 12:04:44
Try heating it with acetelene torch.Thats what I had to do to free up the one on the T0-35 that I just bought.
