Electrical TO-20
Craig
11-05-2001 06:02:00
I have a 12 volt 2 terminal generator on my TO-20. The voltage regulator has 3 terminals, BAT, FIELD, ARM. I want to run headlights on my tractor and was wondering which terminal you would use. My shop manual shows a load terminal on the voltage regulator and the igniton switch running off the ARM terminal. Can anyone explain the right way my tractor should be wired?
Thanks in advance!
Sean
12-03-2001 20:06:39
 Re: Electrical TO-20 in reply to Craig, 11-05-2001 06:02:00
Saw your post and just finished re-wiring my To20. Did you get the help you needed???
DunerWi
11-08-2001 13:39:21
Take a look at these. Some thing should come close to what you have. Normally TO 20 were 6 volt positive ground.
http://albums.photopoint.com/j/AlbumIndex?u=167324&a=1220311
