Govenor Quit
Ian
11-07-2001 15:40:52
I couldn't help noticing the talk about adjusting the govenor. But what would make it quit while the tractor was in use? It's a 1949, 35 Deluxe, and I've have it for years. I haven't attempted to adjust it yet, but it seems strange that while I was snow blowing with it, the engine suddenly started over revving
We've Got A Governor Here In Ca. I Wish Would Quit.
11-08-2001 07:27:13
 Re: Govenor Quit in reply to Ian, 11-07-2001 15:40:52
rod
11-07-2001 18:20:01
Most likely it needs a rebuild either the springs have broken or are very weak best to take it apart and have a look see. regards
rod
Ian
11-09-2001 08:35:21
 Re: Re: Govenor Quit in reply to rod, 11-07-2001 18:20:01
By take it apart, I presume you mean pulling the timing cover? And is it dry behind the timing cover or is it lubed from the crankcase and easier to drain the oil pan first?
