35 engine Id
Jim (Mi)
11-15-2001 10:00:12
My bro-in-law has a massey 35. I think it is a TO-35, since it is gas, all I read is 35 is diesel. Where are the serial numbers to comfirm model + year. I have not seen it, so would like to know where to look before I get there. Thanks in advance.
Phil (VA)
11-16-2001 14:24:06
 Re: 35 engine Id in reply to Jim (Mi), 11-15-2001 10:00:12
The gas engine on the TO35 is likely the Continental Z134. The engine serial number on the block should start with that prefix, ie., Z134.... As the other post said, the tractor serial is on a plate riveted to the dash. The TO35 Deluxe has a two speed axle (6 forward gears total) and a two stage clutch. If that's what you have in my mind you have the most versatile and therefore the most desireable of the tractors of that age and class, especially dollar for dollar.
Jerry in Id
11-15-2001 13:55:28
The I.D. plate for the TO35 is located on the left side of the dash, just under the steering wheel. Both the TO35 and the MF35 have gas and deisel engines, so don,t get a mindset as to what model your brother-in-law has. They are both good tractors. Good luck.
