Which engine?
Andrew
11-23-2001 20:13:53
Hi!
What is the difference between a continental, and a standard engine? Also, how can you tell if you have a "85" engine, which I suppose is the Standard engine, "bored out"Any help would be appreciated. Thanks!
DunerWi
12-02-2001 17:01:02
 Re: Which engine? in reply to Andrew, 11-23-2001 20:13:53
The Z120 TO20 continental has the oil filter in the bottom of the oil pan covered with an approximate 7" cover. I can't tell you for sure how to tell the difference between an Std. Motor Co. 80 or 85 . I think one has the water pump attached to the block and the other has it attached to the cyl. head.
