Fuel level in carb
Tony Voegele Jr
11-24-2001 13:27:12
After rebuilding the carb because of dirt in the system, I cannot find the optimum level in the bowl. First attempt was very rich; now it will start but will not stay running. The drain plug in the bowl has been brazed over because of a previous owners mistake. Is there a good way of checking the fuel level with the carb apart?
Tony
John
11-27-2001 03:19:43
 Re: Fuel level in carb in reply to Tony Voegele Jr., 11-24-2001 13:27:12
Tony, If it is a TSX series the factory setting is 1/4 inch mesured from the gasket to the nearest
surface of the float.
