Loader for TO-20
bill walsh
12-05-2001 16:40:19
Does anyone know if a Dearborn loader, model 19-61 will work on a to-20? It came off of a 2-N Ford.
Phil (VA)
12-06-2001 10:56:02
 Re: loader for TO-20 in reply to bill walsh, 12-05-2001 16:40:19
I think that is the same loader I have on a TO30. Mine came off an 8N. If so, it should fit. I do know the 8N and the TO30 are the same distance between axles (give or take a washer or two anyway). I suspect the 2N and TO20 are the same. Does your loader bolt to the rear axle and have a front pump with stinger shaft connecting to the pulley via 4-bolt adaptor plate? And it should have a rectangular plate to adapt the bolts to the front axle, right? If so, I think it is the same loader as mine and it should work.
