Putting out
Andrew
12-05-2001 22:49:34
Grrrrr rrrrr!
I finally get the sickle bar mower working, and then the tractor quits! It just putted out, down in the paddock. However, it restarted perfectly, ran for a bit, then quit again. The fuel system seems to be blocked. Is there any quick, simple way to check, and clear, the fuel line to the carby? Any help would be appreciated. Thanks!
Mark Hendershot
12-06-2001 06:26:28
 Re: Putting out in reply to Andrew, 12-05-2001 22:49:34
When mine did that the inlet was pluged and I took the glass bowl off and used a 1/4in. hose and blew some air with my mouth up the opening into the tank and it unpluged it. Then I took it back to the shop and removed the tank and washed it out with gas a few times and got the rust out. The problem hasn't happen since. Mark H.
