Did they make a Yellow Ferguson? Industrial?
Mark Hendershot
12-07-2001 22:52:18
Did they ever make a Yellow TO-30 Ferguson? Or maybe a Industrial Ferguson that was yellow? Heard someone mention it befor I think? Mark H.
Scott Morrow
12-25-2001 22:56:06
 Re: Did they make a Yellow Ferguson? Industrial? in reply to Mark Hendershot, 12-07-2001 22:52:18
No they did not make yellow To20 or To30 Ferguson's.I would think this was a county highway dept or just another one of those guy's that can't get the color right.As for the back tires they came with as an option 16.9 x 24 tires possible to get 18.4 tires on them. The front hubs are not stock they only came with 6 hole hubs.
Phil (VA) - Yes I have one
12-08-2001 07:02:51
Yes. I have one. Bottom color is yellow. Came from PA. Has hood cut professionally so can get to gas and radiator caps without raising hood and had bottom of grill off, all for a loader I'm sure. I'm guessing it was used by a small municipality / township, etc. I have a loader on it which came off 8N (they are same length axle to axle). Tractor runs good, but needs some work and needs tires. I may repaint it yellow eventually when I get some time unless I sell it.
Mark Hendershot
12-08-2001 07:40:41
 Re: Re: Did they make a Yellow Ferguson? Industrial? in reply to Phil (VA) - Yes I have one, 12-08-2001 07:02:51
Phil; The reason I was asking I noticed that mine being painted red had some chips in the paint in a few places and it is yellow under it! The yellow is the same shade at every chip. And since my TO-30 sits so much lower and has different type wide solid rims, diameters are 16.1" on rear and 10" on front (tires-18.4 rear & 7.50 front) but he lug patern on the front has 5-lugs with that 3in. dia. screw on bearing cap that maybe this is why mine is a little different than the ones posted on YT Site. Where could I get some information about how they equipted the TO-30s other than stock. I still haven't got a strait answer yet on my different front hubs. Thanks, Mark H.
Phil (VA)
12-08-2001 11:24:50
 Re: Re: Re: Did they make a Yellow Ferguson? Industrial? in reply to Mark Hendershot, 12-08-2001 07:40:41
I can't help you with the hub question. Mine are standard hubs, not like yours, on my "normal" TO30 as well as on "ole yeller."
Jone
12-08-2001 04:47:25
Here in Norway, The Government??? Had Yellow TE`s
I know this because a lot of the parts on mine are yellow..... ..(Don`t like it....)
Mark Hendershot
12-08-2001 07:44:58
 Re: Re: Did they make a Yellow Ferguson? Industrial? in reply to Jone, 12-08-2001 04:47:25
Jone; Thanks did the Gov. Mod. TE-30s in Norway have 5-lugs on the front hubs and a different type of rim? Thanks, MarkH.
