Serial numbers
Andrew
12-12-2001 22:54:40
Hi!
where are the serial numbers on a fergy 20? and what do they mean? Any help would be appreciated. Thanks!
Scott Morrow
12-25-2001 22:38:22
 Re: Serial numbers in reply to Andrew, 12-12-2001 22:54:40
Hi
The ser# plate should be on the steering wheel post blue plate with silver writting. If not an easy way to tell if its a To or a Te is the transmission cover (top where the shifting lever is mounted)is one piece with the steering box this would be a Te. A To these two are seperate email me at jd3155@hotmail.com I have books that list ser numbers and dates of production.
jariikon
12-17-2001 03:03:43
Check the site: Link There was some info about different serial numbers. Hope the site is still alive.
mark
12-17-2001 02:29:39
andrew on the right hand side of the transmission case just in front of the dipstick are three blocks of numbers. these are the date of manufacture.for eg my tea 20 has 16 2 4 asthey were manufactured between the late 40s and early 50s the date of mine is feb 1954.Im not sure if the 16 means the day of manufacture.hope this can be of use to you.
Paul in NM
12-14-2001 07:51:22
Andrew, it you can ascertain that your engine is a Continental and it has the SN plate, log onto the site below, send them an e-mail message with the engine SN (including prefix)and ask Jerry to tell you what year and month the engine was built and shipped to Ferguson. He can tell you as he has all of the old Continental engine specs and production information.
Good luck.
Paul
Phil (VA)
12-13-2001 07:51:45
Main serial number is on plate on dash, held on with rivets. Engine number is on block and begins with "Z120...". Use main serial to look up year made (link at left).
Andrew
12-13-2001 12:27:39
 Re: Re: Serial numbers in reply to Phil (VA), 12-13-2001 07:51:45
Rats!
I haven't got a plate on the dash! Assuming that the engine is original, is there any other way to determine the year made? Also, behind the carby, there is a "85" does this mean the engine is the "bored out" 85 mm type?
JW
12-13-2001 13:54:30
 Re: Re: Re: Serial numbers in reply to Andrew, 12-13-2001 12:27:39
If it's got a Standard engine the engine serial number is stamped on the block on a flat area just below the head gasket, and just to the right of the coil. It will be faint and possibly covered in grunge but if you clean it off and look at just the right angle you'll be able to see it.
They just went from 80 mm to 85 mm at a certain serial number; the two were not available at the same time. I might have the (engine) serial number where they changed over.
Let us know what you find. Regards,
Jim
Duner Wi
12-13-2001 13:41:45
The Continental Z120 engine had a large cover in the bottom of the oil pan that housed the oil filer. It also had a model, serial plate on the left side of the block. To tell the Std. Motor Co. 80 and 85 enginges apart. I believe one
had the water pump attached to the head and the other to the block. I have a early TO 20 with out a dash serial plate also. Mine has # 2651 stamped into the hyd. pump in a semi circle around the plug that the muffler makes it hard to see.
Phil (VA)
12-13-2001 13:34:15
I think there is a way to date it based on engine number, but I haven't done that. Others may know. You might ask a MF dealer on that. Does it have a number on the block that starts with "Z120..."? I'm not familiar with "85" designation. You sure this is a TO, and not a TE tractor? Again, tell us what the engine number is and maybe we can help more. Sorry I'm not more help.
