Alternator conversion run on problem revisited
teadave
12-13-2001 19:18:41
finally got some time to work(play?) in the shop tonight. as you may recall, my 12v conversion didn't like to shut off. would take 15-20 seconds to slowly wind down. turning headlights on would make it shut off asap. well, i took some advice from this board and removed ONE of the bulbs from the side marker light i used to exite the alternator. BINGO! tractor now shuts down perfectly. thanks for all the help!!!!
teadave (who finally has a charging system after 10 years and 10 1/2 months of tractor ownership)
John, IN
12-14-2001 18:00:59
 Re: alternator conversion run on problem revisited in reply to teadave, 12-13-2001 19:18:41
Good for you, this is a good place to get help. I have asked of this forum also and have always gotten the help that I needed and try to help if I can. Every body should pat them selfs on the back.
