Seat
Andrew
12-22-2001 01:34:37
I know this sounds kinda obvious, but is it okay to remove the two bolts holding the seat support to the tran's case? Instead of bolts, it has two nuts, and the bolt's rotate with them when turned. I read somewhere that that area houses the hydrolic ram, which is held on by nuts on top? Sorry this is a bit long- winded, Any help would be appreciated. Thanks!
rod
12-22-2001 05:06:51
 Re: seat in reply to Andrew, 12-22-2001 01:34:37
take a good look at the top cover you will see 4 nuts on studs they hold the hydraulic cylinder to the top cover you can remove the seat bolts no problem the studs may turn right out with the nut on them. regards
rod
