Brakes
Newguy
12-23-2001 00:45:22
Hi!
How do I remove the brake drum from a tea20, once the wheel is removed? I need to get to the pedal assembly, and remove the bar. Any help would be appreciated!
rod
12-23-2001 09:38:08
 Re: brakes in reply to Newguy, 12-23-2001 00:45:22
there should be two slotted head screws that hold the drum on the axle they can be hard to get out but once out the drum comes right off.
regards
rod
Phil (VA)
12-26-2001 12:22:12
 Re: Re: brakes in reply to rod, 12-23-2001 09:38:08
Often, on a drum that has not been off for awhile if ever, you will have to take a sharp pointed punch and ball peen hammer and start the screws by punching one edge of the slots.
