Fluid for hyd/rear end etc??
dbrown
12-27-2001 19:41:14
The dipstick indicates low fluid on the hydraulics and rear end. What type of fluid do I use?
Thanks!
Joe Masters
02-04-2003 08:29:56
 Re: Fluid for hyd/rear end etc?? in reply to dbrown, 12-27-2001 19:41:14
I have a Ferguson TO-35. What type of oil should be used in the rear differential/transmission???
Ray,IN
12-27-2001 20:11:48
Assuming you have a H.Ferguson TO 20-30 tractor. The diff/trans/hyd common fluid is 6 gallons total. If you decide to change the oil, be sure to remove all 3 drain plugs. Use 80/90/wt straight mineral oil for yearround use. If you use your tractor in cold weather(<32F) lots you can substitute 40W mineral oil, but must use 80/90 wt in summer to avoid damage.
