Air in diesel system 23C standard
m jones
12-29-2001 14:00:46
Keep getting air in the injector pump both the top and bottom. Have checked all the lines have found no leaks. Pump was rebuilt was running fine then shut it off and now can't get her to fire up. Any ideas would be greatly appreaciated.
twopop
12-31-2001 21:22:19
 Re: Air in diesel system 23C standard in reply to m jones, 12-29-2001 14:00:46
since the fuel tank is mounted above the engine it is virtually impossible to suck air UNLESS there is a restriction in the fuel line.check the flow out of the tank and all the way to the pump.if the filters arent new replace them.
