54 TO-30 colors
E Jorgensen
12-31-2001 19:34:22
Are the original colors red on sheet metal and the rest gray?
E Jorgensen
01-03-2002 16:11:13
 Re: 54 TO-30 colors in reply to E Jorgensen, 12-31-2001 19:34:22
Thankyou all for responses. Mr Mohrhauser I was unable to locate your photo in photo gallery,however I would be interseted in a paint code.
Mike Mohrhauser
01-03-2002 20:40:58
 Re: Re: 54 TO-30 colors in reply to E Jorgensen, 01-03-2002 16:11:13
To find the photo click on "Tractor Photos".Then in the window at the bottom enter "1952 TO30 Ferguson" and then "search".It's at the bottom of the list.
The paint that I used is all NAPA brand.Paint (rattle can) NAPA 7821,Primer (rattle can)Napa 642.Paint 6019 Ford Gray( it matches better than any thing else that I could find).Reducer NAPA 6040. Hardener Napa 15118.Primer 15200 Napa. Primer reducer.The original primer was Red Oxide but I was not able to find it.
I hope this helps.
Mike Mohrhauser
Mike Mohrhauser
01-02-2002 18:46:54
Hi!
All of the TO30's were the same all gray color.I have a photo of my 1952 TO30 in the Photo Gallery.To look it up faster look for 1952 Ferguson TO30,mike mohrhauser. If you like the colors get back to me and I will post the paint code for it.
Mike M.
mike pa
01-02-2002 12:16:49
TO30's all grey. Your MF dealer should be able to get correct paint.
Phil (VA)
01-02-2002 08:46:30
All the TO30's, unless industrial and special paint for that, etc., were the battleship gray all over. NAPA 99L 3740 is very close. The 35's got into other colors.
RICK
01-01-2002 16:23:40
im not 100 percent sure but i think they were all gray
