Symptom
Bill H
01-03-2002 03:30:31
Over several years an oil sepage has developed around the rear spark plug on my T O 20. The plug is not loose and the oil is not significant enough to foul the plug. What's happening here?
DunerWi
01-04-2002 05:06:11
 Re: Symptom in reply to Bill H, 01-03-2002 03:30:31
Also check the "down tubes" on either side if the spark plug. I have one that leaks a small amout there. Clean that area up good or you won't be able to figure out where oil comes from.
Ray,IN
01-04-2002 04:05:20
I suspect the cylinder is pumping oil. A compression check will supply the information necessary to identify bad rings, bad valve seals, scored cyl liner/piston etc.
