Aussie position control
Curt in Mi.
01-13-2002 17:52:32
Hi Is this device that the guy has posted on here do what Zane's device does? I'm confused about this. Curt
Vaughan Williams
01-14-2002 04:05:31
 Re: Aussie position control in reply to Curt in Mi., 01-13-2002 17:52:32
It is designed to do what Zane's Thang does. It is just done differently. Aussie dollar is quite low against the American and British currencies so their may be a price advantage.
Regards
Vaughan
Jim W
01-13-2002 18:10:12
Looks like it to me. I think how it works is that if the rear arm drops, the white cam on it lets the entire quadrant slide backwards a bit via the force of the white spring on the front. This would have the same effect as lifting the lever.
It looks pretty clever, but not sure how easy it is to unhook it.
Jim
Vaughan Williams
01-14-2002 04:02:29
 Re: Re: Aussie position control in reply to Jim W, 01-13-2002 18:10:12
To gain back draft control all you have to do is tighten the 4 bolts up that hold the quadrant to the body and slide the cam backwards that attaches to the left arm. About five minutes work.
Regards
Vaughan
rod
01-14-2002 06:19:21
 Re: Re: Re: Aussie position control in reply to Vaughan Williams, 01-14-2002 04:02:29
Will this wear the quadrant assembly on the bolts I think it is not made to move repeatedly back and forth like that. I will be testing Zane's device on my TEA 20 and posting the results on my Yahoo Ferguson Club page later on. regards
rod
Jim W
01-15-2002 08:53:45
 Re: Re: Re: Re: Aussie position control in reply to rod, 01-14-2002 06:19:21
Hey Rod,
Maybe you should get one of each and do a comparison for us. By the way it looks like lots of snow may be heading your way so here's a chance to try it out on your front blade.
Jim W.
Frank (VA)
01-14-2002 17:25:45
For shear simplicity, effectiveness and cost, I don't think you can beat the Zane Thang
Frank
