I've searched the archives and the IT manuals for Fergusons and N-series Fords trying to figure out what's wrong with the lift on my TO-30. Here's what I know:It happened suddenly. The lift would not raise. (I had a scoop on it at the time.) When I engage the lift, the lift arms don't even start to strain at the load. But, when I took the scoop off, the lift arms raised, and I could stand on them and they held my considerable weight. The problem is apparently caused by a situation with the draft control mechanism, as I can pull on the hydraulic lift rocker (where the top link attaches) and the lift arms will drop, and the control spring suddenly gets lots of endplay. I've never been inside of one of these beasts, but it looks from the diagrams like maybe the internal spring on the control plunger might be stuck or broken. I know there are lots of guys out there who've had vast experience with Ferguson 3-pt lifts, so have any of you run into this before? Is there another possible cause? HELP! I need this tractor to work so I can get my orchard ready to plant. Thanks, Ben
