Ford Model 1821 Industrial Diesel
Arne Anderson
07-15-1999 18:56:23
I recently purchased a Ford model 1821 Industrial Diesel tractor with a loader and backhoe. It runs and operates well and I have most of the parts to it. I would however like to restore it, and there are a few things that need repair. I beleive it was built in 1958 or 1959, and is the first in Fords Industrial line. I've not found much information about this model. My local Ford/New Holland dealer has told me many parts are now no longer available. If anyone has any information about this model, particularly the power steering unit, I would appreciate your input. Thanks!
Buck Clark
10-18-1999 09:26:36
 Re: Ford Model 1821 Industrial Diesel in reply to Arne Anderson, 07-15-1999 18:56:23
Arne,
Sounds like we have the same unit and the same problems- My 1821 original steering is out and I am looking to restore and replace. The guy I bought by Ford from put in a makeshift steering that you use a lever that you push back and forth. I would appreciate information that you have found if you don't mind passing it on. Have you been able to find out the year of yours from the serial #- I have been trying and only know 1958 to 1959 also.
Edward Szymanski
06-13-2005 09:10:04
 Re: Re: Ford Model 1821 Industrial Diesel in reply to Buck Clark, 10-18-1999 09:26:36
just bought a 1821 industrial
Tony Jacobs
07-15-1999 22:26:06
Arne You are dealing with a dealer that does not want to take the time to look for older parts thats all I have 3 old Industrials like yours and I can get parts for them from my local dealers e-mail me with phone number and where you are located P.S. I also have front wheel assit conversions for those tractors Thanks Tony Jacobs
Bill Roeder
05-14-2004 08:44:20
 Re: Re: Ford Model 1821 Industrial Diesel in reply to Tony Jacobs , 07-15-1999 22:26:06
Tony, we also have an 1821 industrial that needs transmission parts. Can you send us a contact phone or email that can help us out with this? Thanks in advance. Bill.
Bill Roeder
05-14-2004 08:48:56
 Re: Re: Re: Ford Model 1821 Industrial Diesel in reply to Bill Roeder, 05-14-2004 08:44:20
Sorry Tony use this email I left out an i in the address. Thanks, Bill.
Bill Roeder
05-14-2004 08:46:59
Tiny Hutton
07-20-1999 19:23:01
Tony,
I purchesed an 1811 industrial last year and I have been restoreing it. I have come across a steering problem during my restortion. The steering cylinder was cracked on the barrel. Suspect that water entered the into the fluid and froze. Had the cylinder costly rebuilt. Now the actuator cable easily slips on the gear in the steering column. Any suggestions.
