Order Ford 2000 Parts Online
1964 2000 starter switch
John Strauss
08-10-1998 12:52:47
If I want to remove the starter switch from my tractor do I have to pull the transmission top cover? There are no visible bolts or screws holding the switch down so I assume it is from underneath? Or is there a secret?
Gary H.
08-10-1998 14:34:47
 Re: 1964 2000 starter switch in reply to John Strauss, 08-10-1998 12:52:47
: If I want to remove the starter switch from my tractor do I have to pull the transmission top cover? There are no visible bolts or screws holding the switch down so I assume it is from underneath? Or is there a secret?
It doesn't matter if it is a 4 speed or a 5 speed
the shift cover has to come off. The 5 speed is
a little harder because you have to pull the gearshift lever off first before you can remove the
transmission cover
