Order Ford 3000 Parts Online
3000 Generator Woes
David Cox
08-06-1999 03:11:56
This past winter I did some much needed maintenance on my 3000 diesel. I had a bad connection in the wiring harness that was easily fixed. In the past I have always been able to start the tractor and once running turn the key to off only having to turn it back on to run the lights. My gauges appeared to work, operating in this manner. I need to have the generator rebiult and the other day had dead battery.After jumping it off I noticed the gauges only work when the key is on. What went wrong? When the key is on they work fine. Is the normal way to operate the tractor with the key on?
