Order Ford 3000 Parts Online
3000 Switch ON or OFF
David C
08-06-1999 22:54:33
Did some much needed maintenance on my 1970 3000
diesel this past spring. Included was repairing the wiring harness, it had a bad connection, no problem to fix. Before repair my standard operating procedure was to start the tractor and once running turn the key to off to save the battery. The fuel and temp gauges seemed to work fine in this manner. Since repair the gauges only work with the key in the ON position. Is this the normal operating method for a diesel?
