Order Ford 2000 Parts Online
1964 ford 2000 Hydrolics
Curtis
08-23-1998 08:56:21
I have a Ford 2000 that has to warm up for about 15 to 20 minutes before the hydrolics will start working, after warming up I have good hydrolics. Is this normal or any ideas what the problem may be ?
Gary H.
08-23-1998 19:02:57
 Re: 1964 ford 2000 Hydrolics in reply to Curtis, 08-23-1998 08:56:21
: I have a Ford 2000 that has to warm up for about 15 to 20 minutes before the hydrolics will start working, after warming up I have good hydrolics. Is this normal or any ideas what the problem may be ?
Sounds like you have a bad seal in the hydraulic pump. You only will need a seal, o-ring and possibly the torrington bearing to fix the problem.
Curtis
08-24-1998 18:36:08
 Re: Re: 1964 ford 2000 Hydrolics in reply to Gary H., 08-23-1998 19:02:57
: : I have a Ford 2000 that has to warm up for about 15 to 20 minutes before the hydrolics will start working, after warming up I have good hydrolics. Is this normal or any ideas what the problem may be ?
: Sounds like you have a bad seal in the hydraulic pump. You only will need a seal, o-ring and possibly the torrington bearing to fix the problem.
Gary, thanks for the information, i will try that and see if it cures the problem.
