Order Ford 2000 Parts Online
2000 'Molded' Aircleaner Hose
Rick Schaad
08-23-1999 06:10:27
I have been looking high and low for the molded rubber hose that runs between the air cleaner and carburetor on my 1963 2000 (4cyl).
I don't want to use a flex hose, cause one day I hope to restore the 'old girl'. In the meantime I have been trying to use the right parts, maybe that will save some money when the time comes.
Bern
08-23-1999 06:54:15
 Re: 2000 'Molded' Aircleaner Hose in reply to Rick Schaad, 08-23-1999 06:10:27
Maybe the reason you can't find it is because there never was one. A metal tube was used with short straight rubber hose couplers on either end of it, one on the carb and one on the air cleaner.
Rick Schaad
08-24-1999 11:16:03
 Re: Re: 2000 'Molded' Aircleaner Hose in reply to Bern, 08-23-1999 06:54:15
What I have is a molded hose that is duct taped to the carburator end, thought the tape was because it tore but sounds like it is just as likely it was too short.
Maybe someone found a radiator hose that was close to the right shape and size.
Any idea where I could find the right pieces?
