5 something row crop
Chris Jones
08-29-1998 15:49:59
I saw a Ford tractor the other day for sale that is settup like a Farmall. It is a high tractor with the engine offset to the left. It has 3pt hitch and a mid lift using a cylinder in the front. The hood looks like a 600 and the side said 601 Workmaster but the dealer said it was a 5 someting that had the wrong decals on it. How does it compare to 8Ns and 600s? Does it have live lift? Live PTO? How good were they? Thanks for your input.
Chris
Dan
08-30-1998 16:47:42
 Re: 5 something row crop in reply to Chris Jones, 08-29-1998 15:49:59
Man, that's a 500-series offset Ford. Production of the 500-series started in 1958. The 500-series Ford tractor is THE most collectable "Gray Line" Ford tractor. From what I have read, Ford did not produce many in the 500-series because they had a tendency to roll over. IF it is one of the early 500's it is worth a bit to the right person.
The 500-series was similar to the 701-series Ford as far a engine and trans. The 500-series included the 541, 541D, 541L, 541-4, 541-4D, and 541-4L.
Dan
NAA60512
Chris Jones
08-31-1998 20:22:13
 Re: Re: 5 something row crop in reply to Dan, 08-30-1998 16:47:42
Thanks Dan, Do you know where I can get any specs on the net? drawbar HP, size engine etc. I haven't been able to find much.
: Man, that's a 500-series offset Ford. Production of the 500-series started in 1958. The 500-series Ford tractor is THE most collectable "Gray Line" Ford tractor. From what I have read, Ford did not produce many in the 500-series because they had a tendency to roll over. IF it is one of the early 500's it is worth a bit to the right person.
: The 500-series was similar to the 701-series Ford as far a engine and trans. The 500-series included the 541, 541D, 541L, 541-4, 541-4D, and 541-4L.
: Dan
: NAA60512
Dan
08-31-1998 22:39:41
 Re: Re: Re: 5 something row crop in reply to Chris Jones, 08-31-1998 20:22:13
Possibly because there isn't much out there on the 501's? }:-)
Engine- Ford 134 cid "Red Tiger" OHV
Bore- 3.44
Stroke- 3.60
Comp. ratio- 7.5:1
HP- 31.8 w/134 cid gas motor
Dan
NAA60512
