Order Ford 8N Parts Online
8N excess gas usage
Allen Northcott
09-01-1998 06:02:26
I have just acquired a 8N '51 ford that has a motor that was rebuilt within the last two years. The problem that I have is excess gas usage. Gas smokes out of the muffler at idle and load speeds include being sluggish. I have tried to fix this problem by tuning the motor including; new spark plugs, points & condenser, setting the timing and adjusting the carburetor. The only other thing that I can think of is rebuilding the carburetor. Would this be the next step to follow? Help?
E.Allison
09-01-1998 10:35:40
 Re: 8N excess gas usage in reply to Allen Northcott, 09-01-1998 06:02:26
I would check the air filter or a stuck choke. Try disconnecting the air cleaner for a moment to see if the engine performance changes. Also, check to make certain that the choke butterfly in the cark is open
: I have just acquired a 8N '51 ford that has a motor that was rebuilt within the last two years. The problem that I have is excess gas usage. Gas smokes out of the muffler at idle and load speeds include being sluggish. I have tried to fix this problem by tuning the motor including; new spark plugs, points & condenser, setting the timing and adjusting the carburetor. The only other thing that I can think of is rebuilding the carburetor. Would this be the next step to follow? Help?
Allen
09-01-1998 12:20:57
 Re: Re: 8N excess gas usage in reply to E.Allison, 09-01-1998 10:35:40
: I've check the are filter and choke and it is in working order. Any other thoughts?
: I would check the air filter or a stuck choke. Try disconnecting the air cleaner for a moment to see if the engine performance changes. Also, check to make certain that the choke butterfly in the cark is open
: : I have just acquired a 8N '51 ford that has a motor that was rebuilt within the last two years. The problem that I have is excess gas usage. Gas smokes out of the muffler at idle and load speeds include being sluggish. I have tried to fix this problem by tuning the motor including; new spark plugs, points & condenser, setting the timing and adjusting the carburetor. The only other thing that I can think of is rebuilding the carburetor. Would this be the next step to follow? Help?
E.Allison
09-03-1998 12:48:17
 Re: Re: Re: 8N excess gas usage in reply to Allen, 09-01-1998 12:20:57
: : I've check the are filter and choke and it is in working order. Any other thoughts?
: : : I would check the air filter or a stuck choke. Try disconnecting the air cleaner for a moment to see if the engine performance changes. Also, check to make certain that the choke butterfly in the cark is open
: : : I have just acquired a 8N '51 ford that has a motor that was rebuilt within the last two years. The problem that I have is excess gas usage. Gas smokes out of the muffler at idle and load speeds include being sluggish. I have tried to fix this problem by tuning the motor including; new spark plugs, points & condenser, setting the timing and adjusting the carburetor. The only other thing that I can think of is rebuilding the carburetor. Would this be the next step to follow? Help?
Allen,
At this point I would do a compression test on all cylinders.
Bob E Que
09-01-1998 17:02:46
It sounds like your carb is just letting through too much gas. It most likely needs rebuilding which is relatively simple and inexpensive. This should solve your problem.
