Ford model numbers
Bob Albrecht
09-06-1999 21:05:38
I have a Ford tractor that has the following numbers hand stamped on the left side of the engine/transmission (first line) 1201D, (second line) 13892 <>. The symbol after the second number looks like a diamond. What is it. Are parts still available. The gear on the crankshaft, behind the cover on the front of the engine has the teeth sheered off. It is a four cylinder diesel with a hood that looks something like the Jubilee. Thanks.
Jim(UT)
09-08-1999 18:02:43
 Re: Ford model numbers in reply to Bob Albrecht, 09-06-1999 21:05:38
Check out Dan's site. It will tell you probably all you want to know: Link
