1900 inj pump oil
Tom S.
09-07-1999 06:08:44
The manual for Ford compact diesels shows a fill, drain and level plug on the injection pump with instruction to fill with engine oil every 200 hrs. Trouble is mine only has the fill plug at the top and only the bosses where the level and drain plugs should be on the side. Does this pump get serviced or not? Would it recieve oil from the timing gear case? Tom S.
ron
09-10-1999 22:34:57
 Re: 1900 inj pump oil in reply to Tom S., 09-07-1999 06:08:44
on late model 1900 did"nt have drain just add oil in fill plug area not alot of oil
Bern
09-08-1999 20:57:09
Tom, I'm not POSITIVE on this one, but I think what you're supposed to do on these is add maybe a pint or so into it every time you change engine oil. The excess then will run out through a hole in the front of the pump into the timing cover area.
