: I'm looking at a Ford 8600... Runs good, master : cyl for brakes bad....: I will be using it to care for 40 acres, mostly grass : Any comments you about the in's and outs of this : tractor is appreciated.. It shows 10,000+ hours : but there is evidence it has been split. It starts : well, runs smooth, has a few leaks... It came from : a large farm in South Carolina... The current owner : has had it about 6 months and it is to big for his : landscaping business... It would appear the engine : has been rebuilt... as well as the injector pump.. : Sheet metal good, (needs paint) hyd good, tires fair... : What is a fair price... I'm in Atlanta, GA : Thank you for the help and guidance.... This is : my first tractor... Probably larger than I need : but at least I won't have to buy a bigger one later... : : Thank u Berch : berch@avana.net check to see if the pto clutchs and shaft have been replaced they cost 1400 dollars with labor value would probably be about 9000 If a lot ofwork was done to it otherwise 4500. there are a lot of parts t wear out on these bigger tractors. does it have added on turbo? If it does forget it.
