Order Ford 3000 Parts Online
3000 Water leak
Darrell
09-27-1999 09:10:31
1973 3000 Ford diesel. Seems to be leaking water from the joint where the engine meets the transmission. My quesion is, is there a freeze plug on the back side of the motor that requires me to "break" the tractor in half to fix.
Bern
09-27-1999 12:56:32
 Re: 3000 Water leak in reply to Darrell, 09-27-1999 09:10:31
Afraid so, behind the flywheel. Split the tractor and remove clutch and flywheel to access it. Make sure you replace the two plugs above it at the same time.
