Need to know
ajc
09-12-1998 08:32:00
We recently bought a ford tractor believed to be a 2000...not sure. It's blue, 4-speed! How can we find out what model and year it is. Is there a way?
Fireman
09-12-1998 08:42:19
 Re: need to know in reply to ajc, 09-12-1998 08:32:00
: We recently bought a ford tractor believed to be a 2000...not sure. It's blue, 4-speed! How can we find out what model and year it is. Is there a way?
Look on the left side of the tractor, on the flat spot at the front of the transmission. There you will see a series of numbers stamped into the housing (might have to remove some paint, rust, etc.). The top numbers will indicate the model, the bottom numbers will indicate the serial number. Good Luck.
P.S.: It's good to see a post from someone in the same time zone as me. I'm in Gresham, Oregon.
ajc
09-12-1998 14:12:33
 Re: Re: need to know in reply to Fireman, 09-12-1998 08:42:19
sorry about the confusion; FIREMAN:
i found some numbers,one set is 8f 12 c5nn 7006bu
the other is c5nn 4024 u
thanks much for your continued help, the goal is to find a service manual and do some of the maint. myself
we live in wisconsin.
Fireman
09-13-1998 14:33:14
 Re: Re: Re: need to know in reply to ajc, 09-12-1998 14:12:33
: sorry about the confusion; : FIREMAN:
: i found some numbers,one set is 8f 12
: c5nn 7006bu
: the other is c5nn 4024 u
: thanks much for your continued help, the goal is to find a service manual and do some of the maint. myself
: we live in wisconsin.
These are casting numbers. Continue to check on top of the flat spot, left side, front of transmission.
Fireman
ajc
09-12-1998 14:02:00
: : We recently bought a ford tractor believed to be a 2000...not sure. It's blue, 4-speed! How can we find out what model and year it is. Is there a way?
: Look on the left side of the tractor, on the flat spot at the front of the transmission. There you will see a series of numbers stamped into the housing (might have to remove some paint, rust, etc.). The top numbers will indicate the model, the bottom numbers will indicate the serial number. Good Luck.
: P.S.: It's good to see a post from someone in the same time zone as me. I'm in Gresham, Oregon.
ajc
09-12-1998 14:01:48
ajc
09-12-1998 14:00:49
