Order Ford 960 Parts Online
1960 fordson dexrta tractor
john snelgrove
10-10-1999 19:31:35
starts with ether than smokes like hell and runs on one or two cylinders and the pneumatic governer idles up really well and dies until the engine is warm..... then the tractor runs on all three but smokes a lot.... if you work it it runs like a charm but occasionally will smoke a lot and misfire then run like a new tractor... lots of power and very smooth.....but if i try to rev her without a load she will missfire and smoke.....but if i work her she runs like a charm....she only has 3700 hours as she was used as a utility toy since new... the diaphram in the pump is like new and new injectors have been installed...the dealer has no idea what is causing the problem and i am going nuts trying to find a solution....please help if you can because we love and grew up with this little jewel and want to keep her running. THANKS JOHN
