1210 fan belt pulley alignment
Martin
10-17-1999 09:04:45
I know my ford 1210 isn't really one of yesterdays tractors - its only 9 years old - but maybe somebody can solve my little problem. The fan belt pulley came off the end of the crankshaft and because it's weighted I have to put it on in the correct orientation to balance the crankshaft. There is no key on the shaft (the pulley can be mounted in any position) and there are no marks on the pulley or the shaft to indicate the proper alignment, and the manual says nothing about it. Does anybody know where the weight should be when the first cylinder is at top dead center? Or any other suggestions? Thanks Martin
Bern
10-17-1999 12:41:47
 Re: 1210 fan belt pulley alignment in reply to Martin, 10-17-1999 09:04:45
I find it hard to believe that there is no key. Are you sure it didn't shear off somehow? If the pulley is weighted, there almost has to be a key in it somewhere. I'd bet that if you look close that you will find the key is sheared in both the crank and the pulley.
